1 - 3 of 3 Posts
Spent the weekend replacing my valve cover gasket - got everything back together and now I cannot switch out of 2WD. The button lights do not light up at all and the dash reads "SERV 4WD". I do not have any leaks in my cab, and the connection above the head unit is secure.
Has anyone had a similar problem & can give some insight? I do not have access to a Tech2 scanner so this is difficult to troubleshoot.
2004 z71 4x4 i5 3.5L 160k
Since you don't have lights on the control switch, I'd guess you bumped an electrical connection somewhere. Here's the schematics from the service manual. I'd check the grounds, fuses and connectors and see if something jumps out.
342413
342414
342415
342416
I had a problem after my rack was replaced (the second time) I thought it was the actuator , but turned out to be cut wires. I guess tha smacked the wires then replacing the rack. I repaired the wires, and everything worked just fine (I also replaced the actuator, since I had it )
1 - 3 of 3 Posts
