I drove my truck down to FLA this summer and shortly after I got here the Truck would start out in 3rd gear in drive. 2nd will work if you select it but there is no 1st or 4th. Fluids were fine oil and tranny oil were clean as could be. Scanned the codes and got a P0788. Shift/ timing solenoid high. I figured that The 1-2 shift solenoid was bad so I dropped the pan and replaced it. Poured in a jug of lucas with some new fluid but still doesnt work.
After that I was reading 355 and came across an ignition switch issue that might be causing it so I replaced that also. Checked the fuses under the hood everything looks good but nothing has worked.
