Hi Everyone,
I have a 2004 Rado Z71 LS 2wd crew cab with 270k miles on a 4-speed (I believe) auto trans and have been having a hard shift issue come up in the last few months and would greatly appreciate any insight. I love this truck (bought it in 2006) and it is my daily and while I do most of the maintenance myself, transmissions are way out of my scope.
During normal acceleration between 50 to 60 mph, I get a pretty noticeable shift into either 4th or overdrive (not 100% sure) but shifts up and down fine through all the other gears. However, it has no problem shifting under hard, light or feathered acceleration. I had the transmission flushed but the problem continues.
I was talking to a buddy of mine that was a mechanic in the army and he was telling me that the problem is probably a shift servo that is either gummed up, needs to be replaced, or there is a vacuum leak, not allowing it to shift correctly.
So the question is,
1) Is this likely the servo being gummed up or a vacuum leak, or is this a deeper problem?
2) Is this something that a novice mechanic could do? If not, any guesses on cost?
Thanks for everyone's help.
So the question is,
