Another good write up with a lot of good info
Squeaks, Creaks, Squeals, and Groans
Rattles and Buzzes
Clunks/Bangs/Pops
Grinding/Rubbing/Whining/Moaning/Growling
Other Miscellaneous Sounds
Unsolved Mysteries
Perhaps he's providing information for the first post...^^^ Is there some reason you do not start your own thread?
Nice work Justin. It's nice having all this information in one location.
this thread is great!!! everyone will be using this for sure......EVERYONE :lol:
I've got the 5.3 belt chirp. I read somewhere else that it comes from the A/C compressor being misaligned. I believe there was a service bulletin sent to dealerships related to it. I haven't removed my belts to test that theory out though...
A clunk that can be added
Front
Sound: Clunk when turning left or right
Cause: Body Mounts:
Fix: Tighten body mount bolts.
Searching right now for a reference... I've seen this posted a few times on here.
this thread is priceless!!!! thanks Skizzo!
Excellent, excellent work!
Sound: exterior rattle
Cause: hood hinge bolt slightly loose
Fix: tighten hinge bolt
Further notes: this rattle can be difficult to trace. You will hear it at low speeds, as in a parking-lot, etc.
I originally guessed it to be a loose front fender-liner.
A 1/4-inch drive ratchet with socket is needed. Use caution, it's tough to get a ratchet in the space available.
A slip here can scratch your hood.
Sound: chassis rattle/clunk
Cause: body-frame mount, when the weldnut on the bottom of the body breaks loose
Fix: Weld in a new nut
Pic of my right-front cab mount weldnut:![]()
Further notes: (the rust in that pic is only an old piece of sheetmetal placed to protect my carpet)
This one is ugly.. The bolt that holds the body to the frame goes up from the bottom of the frame thru the mount,
and threads into a weldnut in the bottom of the cab body.
The weldnut though is enclosed in a "pocket" formed and welded into the sheet-metal at the cab floor.
Procedure: Locate the area over the weldnut inside the cab, pull back the carpet. Use a torch to cut open a small rectangular hole over the weldnut.
Remove the original weldnut. Place a large castle-nut (size?) in the same location, weld it in place, apply primer to prevent rust. Weld the flap that was cut from the floor to access the nut back into place. When replacing the original bolt, use anti-seize.
CLUNK/RATTLE
Interior (crew cab)
Sound: Clunk/rattle coming from the doors.
Cause: Speakers
Fix: Remove door panels, tighten bolts, IIRC stockers are 10mm.
Oh mein you sir amazing. You've address many noises I have yet to fix and many I have already. Great info and thanks for taking the time.
Would haft to be near destroyed for a u joint to"clunk" while changing gears... Check out the drive pole... Should be loose if it is making any noise... Good luck with your truck !!I have a clunk noise when disengaging the clutch when shifting from 1st- 2nd and 2nd to 3rd. Possibly the u-joints or more likely something the transmission itself?
