I happened to like the turn signal mirrors, but they are a bit expensive, so I am going to go another route... lights...
I have only installed one, and its the driver side. I plan to have 3 on each side, with the middle being dual, DRL and Turn. This mod is a Easy - Moderate to install, and was pretty simple. In the coming days I will have a write up done on it!
Currently this is the Middle Driverside, and is only tied into the turnsignal, to save time, I did not want to bother looking for the signal wires inside the cab, so I just ran a wire from the engine compartment (that was faster for me). The worst part was fishing the wire through the body from the light to inside the cab, which involved 1 hole to be drilled (small) and all those stupid plugs to be removed (Temp)
Total this mod will cost, $25 tops! and that includes, Wires, 6 Lights, electrical tape, and screws.
These lights are grounded through the screws, so only 1 wire needs to be ran!
The mounts also came white, I painted them black quickly because well, white would just look ugly on my colly! I have a Black, Grey, Orange theme goin
