1 - 1 of 1 Posts
STARTER MOTOR MOUNTING
(L20/4.8A,LMF/5.3-4,L96/6.0G); (L20/4.8A,LMF/5.3-4,L96/6.0G,LC8/6.0B); (L20/4.8A,LMG/5.3-0,LC9/5.3-3,L94/6.2F); (L20/4.8A,LMG/5.3-0,LC9/5.3-7,L94/6.2F); (L96/6.0G,L9H/6.2-2); (L96/6.0G,L9H/6.2-2,LC8/6.0B); (L96/6.0G,LC8/6.0B); (L96/6.0G,LY6/6.0K,L9H/6.2-2); (LC9/5.3-3,LH6/5.3M,LMG/5.3-0,LY2/4.8C,LY5/5.3J); (LFT/5.3N); (LH6/5.3M, LS2/6.0H); (LH8/5.3L); (LH9/5.3P); (LM4/5.3P); (LM7/5.3T,L59/5.3Z,LQ4/6.0U,LR4/4.8V); (LM7/5.3T,LQ4/6.0U,LQ9/6.0N,LR4/4.8V,L33/5.3B,L59/5.3Z,EXC HYBRID HP2); (LM7/5.3T,LQ4/6.0U,LQ9/6.0N,LR4/4.8V,L59/5.3Z); (LM7/5.3T,LQ4/6.0U,LQ9/6.0N,LR4/4.8V,L59/5.3Z, EXC HYBRID HP2); (LM7/5.3T,LQ4/6.0U,LR4/4.8V); (LMF/5.3-4,LY6/6.0K,LY2/4.8C); (LMG/5.3-0,LC9/5.3-7,L94/6.2F); (LR4/4.8V,LM7/5.3T,LQ4/6.0U); (LSA/6.2P); (LY6/6.0K,L76/6.0Y,L92/6.2-8); (LY6/6.0K,L76/6.0Y,L9H/6.2-2);
NOT FOR HYBRID PROPULSION ELECTRIC,PARALLEL-PHV,6 KW CONTINOUS POWER 110V/220V 6 KW HYBRID PARALLEL ELECTRIC PROPULSION(HP2)
Capacity: 1/2 TON; 3/4 TON;
Drivelines: 2WD; 4WD; AWD; RWD;
ENG: ENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 5.3L, MFI, V8, GM 5.3Z,FLEX FUEL(L59); ENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 6.2L, SFI, ALUM GM 6.2-2(L9H); ENGINE FLEXIBLE FUEL, (GAS/ETHANOL), 8 CYL, 6.0L, SFI IRON 6.0 (L96); ENGINE GAS, 6 CYL, 4.3L, MFI, V6, 90 DEG 4.3X(LU3); ENGINE GAS, 8 CYL, 4.8L, MFI 4.8V(LR4); ENGINE GAS, 8 CYL, 4.8L, SFI, IRON, GM 4.8C(LY2); ENGINE GAS, 8 CYL, 5.3L, MFI 5.3T(LM7); ENGINE GAS, 8 CYL, 5.3L, SFI , E85 MAX, ALUM, GM 5.3 (LH9); ENGINE GAS, 8 CYL, 5.3L, SFI, ALUM, GM 5.3P(LM4); ENGINE GAS, 8 CYL, 5.3L, SFI, ALUM, HO, GM 5.3-L(LH8); ENGINE GAS, 8 CYL, 5.3L, SFI, V8, ALUM, HO, GM 5.3B(L33); ENGINE GAS, 8 CYL, 5.3L, SFI, V8, OHV, IRON, GM 5.3-4(LMF); ENGINE GAS, 8 CYL, 6.0L, MFI 6.0U(LQ4); ENGINE GAS, 8 CYL, 6.0L, SFI, IRON, GM 6.0-K/N(LY6); ENGINE GAS, 8 CYL, 6.2L, SFI, ALUM, HO GM 6.2-8 H/O(L92); ENGINE GAS, 8 CYL, 6.2L, SFI, ER, ALUM, INTR CLR SC, GM 6.2P(LSA); ENGINE GAS, 8 CYL, 8.1L, MFI (496 CID) 8.1-E(L18); ENGINE GAS, 8 CYL, 8.1L, MFI (496 CID) 8.1-G(L18); ENGINE LPG/CNG, 8 CYL, V8, 6.0L, SFI, GEN 1, GMNA 6.0 (LC8); ENGINE,4.3L(4.3W),CPI,V6,90 DEG 4.3W(L35); ENGINE,5.3L(323CID) GAS V8 5.3-M ALUM W/CYL DEACTIVATION(LH6); ENGINE,6.0L(364CID) GAS V8 6.0-H(LS2); ENGINE,6.0L(364CID) GAS V8 6.0-U(LS2); ENGINE,6.0L(6.0N),V8,MFI,IRON,HIGH OUTPUT 6.0N(LQ9); ENGINE,FLEXIBLE FUEL,(GAS/ETHANOL E85),8 CYL,4.8L,SFI IRON, GM 4.8 (L20); ENGINE,GAS,8 CYL,5.7L,CPI 5.7R(L31); ENGINE,GAS,8 CYL,5.7L,CPI--MEXICO P96(EXPORT) 5.7R(L31)
HPS: HYBRID PROPULSION ELECTRIC, HYBRID ELECTRIC PROPULSION(HP2); HYBRID PROPULSION ELECTRIC,PARALLEL-PHV,6 KW CONTINOUS POWER 110V/220V 6 KW HYBRID PARALLEL ELECTRIC PROPULSION(HP2)
PTS: PT DRESS SUBASSEMBLY INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJA)
TRN: TRANSMISSION MAN 6 SPD, TREMEC, 85MM, 3.01 1ST, 0.84 5TH,0.57 6TH, O/D 6-SPD M/TRANS(M10); TRANSMISSION,AUTO,4-SPD,HMD,HEAVY DUTY 4L60-E/4L65-E 4-SPD HEAVY DUTY AUTO TRANS(M32)
2009 Chevrolet COLORADO EXT CAB STARTER MOTOR MOUNTING
1 - 1 of 1 Posts
