Exactly. If you really wanna get to the exact and prolong your u-joints and needle bearings you need to use an angle finder and place it on the driveshaft with the truck on the ground at ride height. Then once you lower the truck you need to check the driveshaft again and find out how many degrees its off from where it was stock and use that angle shim or close to it for maximum lubrication of the needle bearings inside the ujoints.no there is no generic answer, it all boils down to the exact truck. and nobody can say for sure without using an angle finder to know for sure.
haha, i say it and get "suit yourself bro" and turbizzy says it and gets a "thanks great info". damnit i suck.great info turbizzy. i wasnt sure.. that really helped out alot
You suck bitch :quit:haha, i say it and get "suit yourself bro" and turbizzy says it and gets a "thanks great info". damnit i suck.
