1 - 15 of 15 Posts
Discussion Starter #1 (Edited by Moderator)
Well this is copy and pasted from S10forum and 67-72chevytrucks and I take no credit for the information below. I figured the information could be helpful to some on here:
(For some reason the pictures will not transfer over, for a quick reference go to this link: Frame Notch Based On Strength - The 1947 - Present Chevrolet & GMC Truck Message Board Network )
A lot of guys are notching their frames to lower the trucks stance. As a Mechanical Engineer some of the photos these guys have posted on various websites reflect notches that are scary.
Please note that I don’t have a dog in this hunt; I am not selling anything. Don’t shoot the messenger, I am merely trying to help.
How you notch your truck frame should depend on its original factory design and how it will ultimately be used by you or any future owner. My personal philosophy has always been any change to the frame should restore the original strength, but that is me. I always assume that just because I may never push the envelope of my truck to its rated capacity doesn’t mean the next owner won’t.
Things to consider:
How do you plan to use the truck? If those plans include hauling loads in the truck or pulling a trailer with the truck the frame will see these loads and frame strength will be very important.
Long bed trucks load the rear frame section more than short bed trucks.
A look at various designs using Finite Element Analysis
A Stock Frame (based on a 65 C10) is the baseline for all of these designs. The FEA assumes a factory stock standard coil spring / trailing arm type suspension, circa '65 (I have been told that the suspensions from 63-72 were all very similar) and assumes a bending moment from hauling and towing loads. Worth noting is that if hauling and towing loads are not present the trailing arm suspension style frame has almost no load at the rear axle, only the weight of the frame itself and the truck bed.
Commercially Available Notches
Bolt In
This model replicates the popular bolt in notch, it gains you about 3-1/2" additional clearance. It captures the bottom and the outside of the frame and is ¼” thick. The frame is not boxed. FEA reveals the frame is 80% weaker than stock.
Bolt In Type Notch
Add a welded in boxing plate to the back of this design and the FEA reveals the frame is still 60% weaker than stock.
Weld In (Dim. data was taken from this website: http://www.suicidedoors.com/notches/...step-notchkit)
The half circle notch is slightly stronger than stock (about 10%) and gives about 8" more travel.
Half Circle Notch FEA
The Step Notch is slightly weaker than stock (about 10%) and gives about 8" more travel.
Step Notch FEA
DIY Weld In Notches
Pipe Notch. This yields 2" more travel than stock and is as strong as a stock frame. It utilizes a 3/8" reinforcing pad and a 1/4” boxing plate to accomplish this.
Pipe Notch FEA
Deep Pipe Notch. I saw this being done on one of the websites. It was a boxed installation and it is about 76% weaker than stock!
Deep Pipe Notch FEA
Step Notch made from rectangular tube. Here is one I developed that is made from mitered 3-1/2” x 2-1/2” x ¼” wall tubing. It is about 10% stronger than a stock frame and gains you about 3-1/2" additional clearance.
Tube Type Step Notch FEA
Tube Type Step Notch as viewed from inside
Summary
If you want the frame to be as strong as stock and you want a frame notch deeper than the 2" there is simply no substitute for adding some sort of truss structure, or replacing the frame section with another structural member that has the same or greater section height as the original frame.
Whenever someone starts talking about a deep frame notch (> 2” nom.) and state that just by adding thicker plates to the sides of the frame rails this makes the frame stronger than it was in its original condition, yet they are and not adding vertical height, they do not understand beam analysis.
Some final thoughts
The implementation of any design affects its strength. The final fabrication can only be as good as the welder – fabricator performing the work.
I have yet to see a bolt in notch that will restore the strength of the frame to the factory condition.
I have not seen any manufacturers “certifying”, via a signed document, the strength of their notch kits.
The information posted here is for reference only. Results will vary based on actual dimensions, materials used and the quality of the implementation and fabrication.
^^agreed
Sent from my C771 using AutoGuide.Com Free App
Thanks for the info. This is all great, especially since I am about to lower my truck. Glad I could read it before I got my notch put in.
It's important to note that our frames are already boxed and double walled.
was gonna say that. Those are desings for weak ass frame..
Good info anyway!
Nation Citizen
so that being said, Rich, what kind of notch would you say is best for our trucks?
I dont know anything about it and dont know that I would ever do it but just curious for knowledge sake.
Darth Vader
^^^Thats the one I hope/plan to get
k so i know someone that has a stick welder and is pretty good at it. Would yall recomend using a stickwelder to weld my notch? didnt want to start another thread so just checkin to see if anyone can help. i really want to get a notch soon to go more low:D
That is the notch i have and have had no problems with it
Has anyone found a stronger notch solution for our trucks? The airbagit one looks pretty much exactly like the first notch picture, and then s thread says that even welded it is 60% weaker than stock. I really want to be able to haul a bed full of mulch, etc. with this truck and weakening the frame by 60% just sounds like a horrible idea :(
1 - 15 of 15 Posts
