1 - 7 of 7 Posts
Went to replace my original struts this weekend only to find out all the OEM manufactured struts dont have the lower flange notched out for the coil, they include a plastic spacer to seat the coil. With that being the case, having the lower flange moved downward just ever so slightly to accommodate the plastic coil seat, upon reinstall of the new struts, the lower flange hits the bottom of the bumpstop now. :th_crazy:
I know I cant be the only person that is still running suspensionmaxx that needs struts replaced, but I cant seem to locate any part numbers that resemble the original factory GM strut in the truck.
Any feedback on a solution or a potential part number for a strut that will fit?
Are you running these spacers that go one top
If so it should have came with a bump stop extender kit also but you will have to cut out the old bump stomp mount to match the cut out on the spacer and the shock will mount right back in just fine and have plenty if room to move
Discussion Starter · #4 ·
Using both the spacers at this point.
I removed the bumpstop to try and make some extra room to work, but the plastic spring seat still hits the original when compressing the LCA to put the bolt through the lower strut bushing.
1 - 7 of 7 Posts
