I own a 2005 Chevy Colorado LS with Front Strut (no torsion bars), New to Chevy and Lifting World. I Installed 3" fabtech Spindle Kit, changed the upper & lower ball joints, inner & outer tie rods, I also have a 2-3" Strut Spacer that mounts top of strut to frame, to get 5 - 6 " lift.
My Problems are:
My Upper Control Arm is Stuck on Down Position
When i jack up the vehicle from the Lower Control Arm to see if upper arms move, The whole car goes up
I also running stock tires for now, once my lift works out. I already have a 17X9 Fuel wheels with 1.5 spacer ready to install, I'm just trying to achieve a 5- 6" lift so i can go and install hopefully 33" tires after some cutting at tire shop.
I don't want to install Body Lift because they don't look good, and i want to stick with the Fabtech Spindle because i cant return it anymore. I don't know if i should purchase an upper control arm and the problem would be solved (Found Michigan Metal Works makes arms but don't know the length it should be 1/4 longer or 3/8 longer , or is the lift to high for the vehicle and cant be done.
Sway bar also i want to install back on the car, I believe its called a sway bar drop kit? Where can i get that?
or how tick does the bracket need to be to make it work, maybe i can make one from steel?
My Problems are:
