1 - 20 of 29 Posts
Finally finished the install. The truck is running really rough though, but I half way expected that because I have a lot of other mods and I think the magnuson tune is made for stock setup. The idle is surging and not dropping off, and some pinging. Anyone else experience this problem after the install? I hope a tune will fix this. Also going to swap pulleys at the tuners to a 8psi pulley.
Mods I have:
Intake
Headers
Full exhaust with cats
Efan
NGK TR6 Plugs
Boosted V8
the only problem i could see is the headers being as the 02 sensor is reading a whole lot different parameters.... The tune will fix everything but i would be very easy on the truck until you get it there. The last thing you want to do is lean the motor out. Also with that pulley size you might run into fueling issues...
Dyno tune to be safe
I had the same mods when I finished my install and it dirint run rough at all,,, get it dyno tuned for best results,, I'm running a 3.4 pulley that's pretty much as low you can get without having fuel issues, I'm at around 8 or 9 psi can't remember
his sig says it was dyno tuned
maniac mechanic
Just get a dyno tune. For what you just invested and the cost of repairing or replacing the engine it more than pays for itself in peace of mind. Plus they will get every ounce of safe usable power out of it.
Discussion Starter · #15 ·
I am getting it tuned Friday, was planning on it. I was just wondering if any one else's truck ran rough with similiR mods after sc install.
I did send my pcm to Magnuson to get it programmed,,,, at least be able to take it to get dyno tuned,,, after that i took it to my tuner to get it dyno tuned and he deleted all the check engine stuff due to the cats being gone,,,, I'm running 93,, but I think your fine with 91
maniac mechanic
Hmm I would think with the money you spent on the blower that the tune would run it better than that from them. Could be that the 91 has a lot of ethanol in it as well, that's pretty common. I'm lucky here we can still get 93 which is pretty good at most stations.
I started at 369rwhp with the Magnuson tune and after I got it dyno tuned and did a pulley swap I ended up at 416rwhp 430rwtq pretty good diffrence
1 - 20 of 29 Posts
