This is probably posted somewhere I just can't find it in a search. What are yall getting from the ground to the finder lip after torqing? I'm getting about 38". Also shouldn't the steering be as close to vertices as possible. I saw the reamer thread should I do this? Did you used a washer on the other side or is the hole still small enough to give a good firm hold?
Sent from AutoGuide.com App
