1 - 20 of 31 Posts
Yesterday I hauled a couple of 200 liters drums in my truck, we rolled the drums on the side to move them from a pallet to the bed.
While doing this I heard how the tailgate was crushed, here the pics of the damage.
I honestly thought that a 200L drum wont cause any damage to a tailgate protected with a bedliner. But looks like the only way to load drums without damage is by pushing them while keeping the drum vertical all the time.
This post is just a "heads up" to prevent any other member to get the tailgate dented.
The 55 Gal drums I deal with regularly weigh between 450-750 lbs based on whats in them... this is well more than enough to destroy our tailgates
Discussion Starter · #6 ·
450 lbs each. but still I´m shocked I´ve seen people abusing full size trucks tailgates with even more weight than that with minor damage.
My assumption was that our tailgates were designed with the same internal reinforcement and structure than the full size ones and since they are smaller I even thought they were more capable.
maniac mechanic
Everybody I know pops the tail gate off and lines the pallet right up with the bed. It only takes 2 seconds on new trucks to remove. Even then though the bed floor will still dent from those barrels. The sheetmetal is like 1/16" to 1/8" and ribbed or not can't handle 400lbs on an area the size of a sliver when you tip those barrels.
One of the ribs on my tailgate is partially collapsed like that as well from an excessive point load... BUT the tailgate itself isn't 'bent' like a 'v' or a 'u' or whatever you want to call it.
Throw a piece of plywood down next time to distribute the load more evenly -- and it makes it easier to slide the barrels on. Occasionally I haul 55gal poly drums of diesel to get fuel to heavy equipment used on remote properties (i.e. not getting a fuel truck back there, but a Colly will!).
Nipple
This. C'mon Fito, you're an engineer right? You should understand how forces and stresses work.
Man I wish I had a forklift to transfer barrels. Normally we're leveling the ground and then stacking pallets to get the same height as the bed!
Discussion Starter · #18 ·
Yeah, that´s what I will do next time.
1 - 20 of 31 Posts
