1 - 9 of 9 Posts
My tailgate will not remain closed all the way. On the passenger side the gap is wider. Can I shim my latch with washers to make it latch better? Or do I need something else?
Lifetime Member
My 2006 has a 55 5/16" wide tailgate and just under 1/8" wide gap driver side and just over 1/16 passenger side.
Distance between bed sides at the tailgate is 55 1/2". Any chance your sides got pushed out somehow?
Discussion Starter #4
Someone must have put a bed side on it. The gap is wider at the top the side that will not stay shut
I would consider using a ratchet strap to pull the top of the wide side inwards a smidge so it will start latching again.I
Run the strap from the top of the wide side to the base of the opposing side.
1 - 9 of 9 Posts
