I didn't realize that spacers don't work with torsion bars... new to this. Im not looking for anyone to talk me out of it just making sure im not gonna hate my truck afterwards that's all. But I can just undo it so no big deal. So full tb crank and bj flip will be a max lift up front without having coilovers or sub-frame lift?
Don't some people throw a spacer with the bj flip? Is this bad?
My comments were probably not taken as intended (since it's not possible to read how a person sounds).
I just meant that the ride is harsh but not so much that anybody would want to say to stay away.
Spacers for the ball joint is for something entirely different. Because of the way the upper ball joint is mounted to the UCA, flipping the ball joint, then possibly adding a spacer helps reposition the UCA more near the stock location. Not exactly, but it tries to make it closer.
Also, a BJ flip (and/or spacer) will not at all lift the front. The primary 2 purposes for that is 1) less likely to crack the UCA at the bj mount due to binding, and 2) Helps with getting the front end back into spec during alignment.
Basically:
Lift the front using torsion bar cranking until the lip of the front fender is about 24" from the center of the hub when the vehicle is parked on a level surface. Flip the ball joint if desired. Lower the front differential on a 4x4 model by about 3/4" using a spacer or stacking washers. Lowering the differential prolongs wear on the CV joint as the axle half-shafts are not driving at angles that can prematurely wear the joint out.
It is a pretty simple task to do. In many instances, no new keys are necessary. But if the torsion bars have sagged enough, then the truck won't meet the max height of ~24" without the use of aftermarket keys.
Installing shackles or an AAL is pretty simple as long as the vehicle isn't rusty. If so, removing the bolts from the shackle bushings can be a struggle. The bolt and bushing become rusted together and most often requires being cut out and replacing bushing and hardware.
