241 - 260 of 291 Posts
Re: The Insanity Project - BullMaxx Monstalined
Bully...that's way sexy. Can't wait to do this to my bumpers, but we're in the teens here in MidWest...:(
Next time, if/when we build another new house, garage is getting insulation + heat! :D
· 252,000+ Miles
Discussion Starter · #244 ·
Totally worth just renovating to that if you need. My garage has an industrial blower installed at ceiling high run off natural gas with a thermostat. Uninsukated fiberglass garage door and maybe r13 in the attic above.
· Ride, Boldly, Ride
Re: The Insanity Project - New Pics
Those gauges tho... :eek5:
· 252,000+ Miles
Discussion Starter · #255 · (Edited)
A small fortune in gauges right there.
Go big or go home, brother. The ScanGauge is mounted above the mirror for Trans temp, engine oil temp, and mileage stuff.
THAT is awesome! Great work, man.
Thanks man. Not done yet, the list never ends but at least it's smaller now.
I used to run autometer carbon fiber in my grand prix back in the day....I like the cobalt.
The only thing I have left is a clock in cobalt...decided against it. Redundant.
· 252,000+ Miles
Discussion Starter · #256 ·
My next interior things are the mass backed carpet and sending my interior stuff all to captainrab to get the leds colormatched. We had...issues...with the first batch and the replacements don't match the old bulbs in shade or brightness so we have to yank em all and start over. By the time we're done everything in the truck will match the cobalt color scheme.
· 252,000+ Miles
Discussion Starter · #257 ·
Started having a p0300 whenever it rained...and have a p0455 even though I replaced the gas cap and canister in the back of the truck...twice.
Smell of gas near the gas tank 24/7 and a foaming bubbling sound coming from the tank when I fill up hinted to me that my sending unit on the top of the tank has finally started to crap out after 11 upstate NY winters of being covered in salt and road grime.
Then I watched when my engine stumbled and triggered a p0300, it was always at a full tank or an almost empty tank. When it was full and throwing the code, there was no gas smell coming from the tank. When it was empty, my fuel pressure would bounce from the 57-58 solid it should be down into the 20's and 30's.
At a half a tank, if I stomped on the gas, the fuel pressure would drop into the low 40's.
Time to order one up and swap it.
· Premium Member
If you wouldn't have installed that fp gauge you may have never figured that out.
Gauges are already paying off in diagnosis time :thumbup:
I haven't taken a peek to see what the top of my fuel tank looks like. I think I should, it's seen 11 years of minnesota(PO)/south dakota winters.
· 252,000+ Miles
Discussion Starter · #259 ·
I've got some pics to post in a second.
Honestly if you want to look at the top of the tank, take your drivers rear fender liner off completely and get a flashlight. It was scary what I found. All fixed now but holy shit.
· 252,000+ Miles
Discussion Starter · #260 · (Edited)
So here's what was happening;
I had a p0455 that wouldn't go away since fall. I replaced the gas cap and the canister but still had it, making it another problem. It also threw p0300 stumbles when it rained or after a high pressure car wash, but it stopped when winter came and just the p0455 remained. Tank area always smelled of gasoline, too.
When the weather started warming up again and it rained, it would p0300 again - making me wonder wtf rain had to do with a p0300...bad electrical connection or ground? So I ripped down all the electrical connections to the injectors, the grounds, and the plugs, cleaned them and put them back together, and replaced the plugs...problem stuck around when it was raining, but it always took a while...an hour or so of driving in the rain and then it wouldn't go away when it got dry for a day or so.
Once my gauges were installed, I noticed this pattern (which led to my diagnosis).
Low fuel in the tank would equal low fuel pressure, and a lean condition with a stumble below 1/8 tank. The lower the fuel level, the lower the fuel pressure. Full tank would stay at 57-58psi, half tank would be around 40 at WOT, quarter tank would be down around 20, and lean combined with crazy high exhaust temps - my plugs were BURNED.
Low Fuel
Low Pressure
Lean w/p0300 stumble
Over 3/4 tank
WOT at 3/4 - look at the EGT - Almost 1,400.
All this led me to believe that it had to be a rusted out and destroyed fuel sending unit - constant massive evap leak message, with fuel pressure varying depending on tank level along with a crazy lean condition when almost empty (from too much air getting into the fuel sent to the engine coupled with the low pressure condition).
So I dropped my gas tank and found this;
Looks like 12 winters of buildup without maintenance may have killed my sender. Yep. I can see the gasket without removing the sender. There is the massive air leak as well as an explanation of how it stumbles in the rain (high humidity with extra air getting in the fuel send is basically water in the gas. I drive 300-600 miles per week and fill up from multiple stations so I knew it wasn't bad gas).
Oh hey, was this my locking ring? Tried to find one on rockauto, amazon and gm sites - none available. Check the local ac delco outlet, 12 days if they can find one. Check the dealership, none in the area, none in the system. Nationwide search was the only option.
What. The. Fuck.
Dude, really?
So I cleaned it up, to find...4 of 5 locking ring retainers have rusted away
I started looking for new 04-05 tanks...out of stock, zero aftermarket support...and no wrecks locally with in-tact rings (all suffered the same fate as mine in varying degrees). $750-1k plus shipping for a new tank shipped in from elsewhere. Locking ring did arrive to the dealership so there was that on my side.
I pumped out the rest of the gas, let it dry in the sun, then vacuumed the shit out of the interior of the tank with a shopvac.
I'm not sinking $1k into a gas tank without any other issues than the lack of locking ring support (especially since it will just do the same thing without maintenance in 10 years) so I popped in the new sending unit, gooped around the gasket with permatex blue fuel resistant gasket dressing and sealer, pressed it in, got the locking ring on the one side and then used 2 #10 stainless panhead screws to hold 2 of the other tabs down evenly. Then I dumped 2 full tubes of permatex around it in 4 coats over 2 days to get this result;
Problem fixed. No more p0455, no more stumble when it rains, and a solid 57-58 psi regardless of fuel level in the tank. EGT is back down around 1250-1300 at WOT instead of 1400+, no more crazy lean fuel mix
