So I have been dealing with my truck going into reduced power mode every single morning for months now. I get the whole array of throttle body codes. Sometimes it's a different one each day. The most frequent is p2135, 2101, p060e. The kicker is that it will only do it when it is cold. Not engine temp cold, but outside air temp below 50deg. Once it is warm outside i have absolutely no issues. I have replaced the pedal, throttle body, tb pigtail, grounding blocks on fender wells, battery, alternator. I can't find any chaffed or broken wiring. I'm starting to think it is the pcm. Do any of you have any other ideas?? It's to the point that I want to light my truck on fire by the time I get to work (which is only 15min from my house, and most mornings it's gone limp mode 6 or 7 times).
I've searched and am at a loss other than replacing my pcm.
