You have two separate issues, providing that the smoke is coming from around the throttle body. Do you have any other codes set?
P0411 is an air pressure problem only related to the Secondary Air System. Fixing a possible throttle body leak will not do anything to cure the P0411 problem.
Unless the throttle body has been physically damaged, the only source of a leak would be where it mounts. Replace the seal and smoke test it again.
