thanks cart, busy day, will check those numbers out and see what comes up. btw, had a no start after replacing the timing chain. while troubleshooting i got it to start with the CMP sensor disconnected. research indicated ground or incorrect timing. verified 5volts to the cmp and checked grounds. decided to take it all apart and rechecked my marks and took pictures this time. i had issues installing the exhaust sprocket and i think maybe damaged the clutch mechanism, so put a new one in. Crossing fingers that was it.
