31's, not 33's.U can clear a 33x1050 at stock height on stock offset wheels
What the heck, Whip, I thought that had been made a sticky long ago? :th_1j2q1i:
Nope, never got sticked yet. I'm currently assembling the thread that will hold the chart though for easier viewing.What the heck, Whip, I thought that had been made a sticky long ago? :th_1j2q1i:
True, I'm going with the TKO tread so I'm sure they'll be a bit different from my kellys, that and mine are bald, so there is tread to account for. I should be ok though, I'm running a 2 inch crank, AAL, and 1.5 inch body lift. The tire shop I checked with is 99% sure I'll be good to go. I'm checking one more shop for pricing purposes and then ordering tomorrow to be installed later this week. I'll post up results then.Measurements from different tires are going to be different. I know of only three 33 10.50 15 tires out there, Two are BFG and one is interco. If you are measuring from a stock tire on your truck it is a very different kind of tire and a different construction from the BFG and the Interco. Don't be surprised if you have more rubbing issues than you think. Not saying you cannot run them, just be prepared for the issue. No two tires are the same.
