1 - 20 of 32 Posts
CHEEZEDOODLE
im about to buy a set of wheels that are 20x9. what does that equate to in tire tread width? 255? 245?
please help!
275 is a good width for a 9" rim, not sure you could find a size that would fit though.
you'll want atleast a 255.
:yeahthat:
CHEEZEDOODLE
Discussion Starter #4
i found 275. would that be better? for some reason 275 is cheaper than 255. i wonder if 275 would have good sidewall ridgitity????
What size is the 275? You need to worry about overall diameter as well. You're running 255/50/17's or something like that right now right?
CHEEZEDOODLE
Discussion Starter #6 (Edited)
235 55 right now on stockers. i didnt think about rubbing. is a 255 stretching it for a 9 in rim? i dont want it to look or ride fucked.
im buyin those wheels dc has. shhhhhhh. dont tell him. unlike him tho, i have about 2 in of clearance in my wheelwells.
CHEEZEDOODLE
wait a min. how the hell did i get rep power all the sudden?
A 255 will look a little stretched, but should be fine.
I just punched the #'s into a tire size calculator.
235/55/17 = 27.18"
255/35/20 = 27.03"
Those would be the same diameter as what you've got now.
CHEEZEDOODLE
Discussion Starter #11 (Edited)
but im lookin to get 275/55/20. whats that equal? think that will work without rubbin? i dont want a tire so thin. it rides too harsh with my chopped 4203 springs.
thank you all so much.
woops!
woops!
275/55/20 will be hugenormous. That's a 32" tire, it would barely fit a Z71.
rrcn, what was the size Italian7 was running on a 2/3? 255/40/20 or 255/45/20? Whichever one it was it would probably be a good size for you kerad.
He's running a 255/45.
Are you dropped, Kerad?
I think he's a ZQ8 with 4203's and 2" blocks.
edit: He said in his last post he's got cut 4203's.
Probably at a 2/2 drop then.
I don't know if the 255/45/20's would work then....
Looks to be there may be too much sidewall. :shrug:
He should stick out more than you unless he has more back space then he would have to worry about hitting the inside upper fender well.
CHEEZEDOODLE
Discussion Starter #18
ended up getting 275/45/20. should be big and comfy. nice wide foot. ill trim the fenderwells if i need to. just couldnt stand such a small tire on such a big wheel. transmition is already clunky and rough enough. ill post pics when shit is straight. also have a trainhorn comming in real soon. lots of chrome goin under the body. OH YEA! gotta love the common sence in that!
thank you all for your info.
Honestly I don't think you're going to be pleased when you try to bolt those up. That's a massive tire for a lowered truck, it's almost 30" in diameter and a good 2.5" bigger than your current tire. That's the same tire Silent Images is running, on a stock height Z85.
I'm dropped 3/4 and rub my 255/35/20's. I've rubbed them so much, I've rubbed half the life of the front tires away....
And these are 27" tall tires.
And being dropped 2/2 is the same drop I have in the front, but an inch higher in the rear. I'm with Brakenit, I don't see 30" tall tires bolting up.
Seriously, please prove us wrong though!! I'd hate to see you have major rubbing issues.
1 - 20 of 32 Posts
