1 - 9 of 9 Posts
Fit... yes. Recommended... no.
As far as rubbing...How about a little info on the truck?? 4x4? 2wd? Lifted? Stock height?
The more info you give the more help you will get
its 2wd not lifted as of yet I am doing a 2.5 in lift all around and why is it not recommended
stock z85? no lift and 31s equals lots of rubbing. now after the 2.5 inch lift with a little bumper trim and a little on the inner fender and your golden i have 31s kenda klevers on 15x10 deep lip wheel and i dont rub at either lock unless in a hard suspension flex
Yes stock Z85 for now I have looked into body and suspension lift
31's on a stock height z85 2wd will rub.
I wouldn't put a 10.5 inch wide tire on a 6.5 inch wide wheel. But that is my opinion. If you are cool with it go for it.
yeah I wont do that I will upgrade the rims one day like the looks of the stock rims whats the widest would you do on that rim 255?
9.5 inch.
30" inches on stock Z85 wheels is the biggest I went with my 09 rado, and that was after a 2.5 Ready lift kit was installed. Little rub in the frame at full lock nothing to be worried about since my stock 2012 Z71 4x4 rubs at the exact same place at full lock with all the factory adjust on front suspension.
1 - 9 of 9 Posts
