torc specs
895 Views 3 Replies 3 Participants Last post by  70Bronco
Does anyone know the torc spec for the axle bolt (36mm) on my 05 Colorado?
1 - 4 of 4 Posts
While the torque mentioned in the video (191 ft/lbs) is correct, per the Service Manual, there is no mention of a "lube torque". Keep in mind that if you grease the threads of the nut, as mentioned in the video, and set the torque wrench at 191 ft/lbs, you will actually be exceeding that torque.
Thanks for the spec. I changed th hubs on both sides today and it took about an hour and a half each side
1 - 4 of 4 Posts
