1 - 7 of 7 Posts
Whats amazing is how quick the aftermarket is responding
I called Bell Tech weekly for about a year before they started making something beyond springs and blocks
This is starting to get really exciting for the people that are looking to upgrade to the new truck! I'm thinking some of the extra stuff is the move to away from torsion bars. They have all this technology from the tacoma arms, just had to take the measurements for the colorado/canyon (sure it was slightly more complicated than that)
Apparently, this kit is now for sale, though unsure if it's legit...
http://performancelifts.com/Total-Chaos-Colorado-Canyon-Upper-Arm-77504.html
This Total Chaos Fabrication Upper Control Arm Kit # 77504 is designed for use on the new 2015 model year Chevrolet Colorado and GMC Canyon 2wd and 4x4 trucks. This item also fits the 2012 and newer Isuzu D-Max sold outside of the USA. Please note, this item will not fit any older body style Colorado or Canyon models. If you want to install larger tires and also enhance your vehicles suspension performance the Total Chaos Upper Control Arm and the addition of a performance coilover will provide just that. The Total Chaos arm is designed to maximize front suspension travel and improve the strength and reliablity of the GM IFS suspension. Total Chaos upper control arms feature uni-balls instead of ball-joints and are designed to be installed with aftermarket performance coil over shocks. With the Total Chaos upper control arm (UCA) and aftermarket extended travel coilovers you can achieve up to 2" of lift and an additional 2" inches of extra droop wheel travel to your 2wd or 4wd truck.
Total Chaos upper control arms feature uni-balls instead of ball-joints and are designed to be installed with aftermarket performance coil over shocks. With the Total Chaos upper control arm (UCA) and aftermarket extended travel coilovers you can achieve up to 2" of lift and an additional 2" inches of extra droop wheel travel to your 2wd or 4wd truck. King Racing currently offers one of the first coilovers designed to get the most performance out of the Total Chaos UCA. To make installation as easy as possible, Total Chaos includes special CNC spindle adapters that allow this system to be 100% bolt on.
Each Total Chaos Fab # 77504 Upper Control Arm kit includes a pair of powder coated upper arms, uni-balls, bushings and sleeves, all mounting hardware, hi-misalignment spacers, zerk fittings to lubricate control arm pivot bushings, and installation instructions. For more information on this or any other Total Chaos product, please click on the "ask a question" link located at the very top of this page.
This item ships for FREE via our Standard Shipping service to any address in the 50 United States of America!
1 - 7 of 7 Posts
