1 - 2 of 2 Posts
Trying to install trailer lights. I seen a “plug and play” that’s supposed to connect to the plugs in the image. Long story short they don’t fit just right. A few of the “teeth” are chipped. Kinda weird because the truck lights work just won’t plug into the actual cable for the trailer lights.
The question is does what is the cable in the picture actually called and would replacing possibly allow the trailer light cable to connect.
That connector is called "C401Trailer Accessory Harness to the Chassis Harness". You posted no clue what "plug and play" harness you are trying to connect to the truck. Have no idea what "teeth" you are referring to. If you are trying to use an aftermarket harness I would suspect that to be the problem, not the OEM connectors.
The OEM harness, referred to as the Trailer Lamp Module, is PN 25861049.
1 - 2 of 2 Posts
