What year truck and what isn't matching up?Can someone confirm if the following trailer hitch came from the factory? I got it from the junk yard. I’m trying to wire everything together but it’s not matching up.
My truck is an 08, I pulled it off an 07-10, it was a while ago, barely got around to beelining it. It bolted up the same with the 4 bolts on each side.I believe there was some sort of change-over in the rear rails after 08 that impacted hitch install. Yes that looks like a factory hitch. What year did it come off of, and what year is your truck?
