1 - 8 of 8 Posts
I just put stock bumper back on truck with hitch and new harness. Installed everything clipped in new harness. I went to hook up trailer to check lights and I have nothing.
I have the 7 blade to flat 4 adapter. When I plug in adapter there’s 1 red light, 2 do not light up. When I plug in the flat 4 to the truck now it shows 3 red lights. So I’m assuming power is coming from the truck. But I got nothing coming on the trailer. in 10 years I never hooked a trailer to this truck so I’m new to this.
should I just go through wires and test light everything? Or am I missing something stupid. I’m guessing the trucks ground is in the harness? And the trailer ground is hooked up on the neck of trailer.
any help is appreciated.
CALI BOSS
What kind of tail lights do you have? If they're LED, the trailer harness will not work
Sent from my SM-N960U using Tapatalk
I have LED reverse bulbs n LED license plate bulbs. Not the whole unit ones
CALI BOSS
Have you tested the trailer on another truck or another trailer on your truck? Confirm all lights are working on the truck?
Ya bought it from My uncle n I saw it working when he dropped off. Been sitting since for about a month. But I will again today on my brother in laws truck n see
Discussion Starter #6
Ya I hooked truck up to another trailer and everything worked fine. So it’s something in my trailer that’s off. Gotta be cut or wire off somewhere
Figures it out. Bad ground and then saw a random wire not connected and that happened to be the power for the side markers. Thanks for the help DBNISSAN
1 - 8 of 8 Posts
