yup... too many things can go wrong to justify running this setup, the radiator trans cooler just cost me new freshly rebuilt trans, because it failed on me and it contaminated my trans fluid with engine coolant, to the point the trans began slipping.
also, chances are if your running your engine hard im hot weather, you will have an easier time running a cooler trans by just running an external cooler...
Seems like regular checks of the tranny dipstick and coolant recovery bottle would indicate a leakage issue.
An auxiliary cooler is an external cooler, no?......and if u run an auxiliary cooler inline with and after the factory rad cooler, fluid should run cooler, no? With an auxiliary cooler inline with and after the factory rad cooler the fluid does have a second chance to be cooled, no?
Your recommendation to eliminate the factory rad cooler is ill advised unless u also recommend installing a gauge to verify/prove fluid is at least as cool as it was with the factory rad cooler. If u don't have a gauge to verify/prove your statement, then all u have is an opinion/guess. I damn sure wouldn't eliminate the factory rad cooler, without installing a tranny fluid gauge, based on someones opinion that I read on the Internet.
Eliminating the factory cooler and guessing at tranny fluid temps..............really?
