Have you tested your battery? Maybe the voltage is low the PCM/BCM/TCM are not getting enough to operate correctly. All 3 seem to be in play on this one.
How often do you drive it?
Wouldn't that be the alternator and not the battery? 20 miles a day tops.Have you tested your battery? Maybe the voltage is low the PCM/BCM/TCM are not getting enough to operate correctly. All 3 seem to be in play on this one.
I don't have a scanner. I heard about the tb recall. The check engine and the traction control lights are on.Have your vin checked for the tb tps recall on the GM 5.3 motors. I believe its posted on our site here someplace. Getting any codes to search?
That sounds like my problem. What about traction control light? How is that related?http://www.355nation.net/forum/serv...ulletin-sb-11273-throttle-postion-sensor.html
The Campaign has been extended to 2011 models.
