true/false? replacing ABS on the vehicle?
1611 Views 4 Replies 4 Participants Last post by  1BADI5
Ashamed to say I don't recall (if I ever did know) but can the ABS sensor be replaced on the vehicle without removing the hub + rotor?
... now I'm recalling, the answer is no, because the sensor is concentric with the hub, yeah?
wow, I'm batting 1,000.
1 - 5 of 5 Posts
It depends on the year truck you have because the early 04-08 year had the incorporated sensor and the later 09-12 year had a separate pick-up sensor.
Now that I did not understand about the later assemblies..
And timely with something on a different vehicle going on also,
Even that alone is reason to upgrade during rebuild to use the later brakes.
.. with a rear disc conversion I'd be just as happy to run a pre-'09 rotor up front for less unsprung weight.
The smaller rotors feel great on a '05 crew with TSMMC rear disc conversion.
On a std-cab I would expect even better..
Rears being independently suspended they should be outstanding.
-- Being able to replace the (front) sensor is another matter altogether, plenty reason to go '09+.
thanks!
The 09-12 have replaceable pickups :cry:
So much work on the early models... :lmao:
Yes, you have to remove the hub to do the job! @Rick_crew
1 - 5 of 5 Posts
