I need to know if anyone knows about tubocharging the I-350's. And knowing what the boost should be set at.
You're boosting your truck's frame? ...maybe you're boosting your front driver side coil spring?I need to know if anyone knows about tubocharging the I-350's. And knowing what the boost should be set at.
He's being a dick because the question has been asked and answered 1,000 times by other people that aren't going to follow through with using the information. The information the OP is looking for could have easily been found had he looked around.Econo, im not sure if you are just a dick but most assume turbocharging would refer to the engine and not sure if you noticed or not, but the I-350 is a truck that's pretty "similar" to ours. It'll be the day when you can actually provide useful information to a thread instead of attempting to shoot people down every chance you get.
Fact is, not many have ventured to turbocharge these trucks so there's not much knowledge on a "boost threshold" and that number would depend on what size turbo you have.
Well, that and he originally posted this in the chassis section.He's being a dick because the question has been asked and answered 1,000 times by other people that aren't going to follow through with using the information. The information the OP is looking for could have easily been found had he looked around.
