Item Number: 004
Part Number: 89040243
Description: JOINT KIT. Propeller Shaft Universal Joint.
JOINT KIT,PROP SHF FRT UNIVERSAL. Required: 01
For: ST1 (2004-2011) (2004 - 2011).
Joint kit dimensions is 1.70 in × 4.30 in × 4.30 in. This joint kit weighs 8.88 pounds. Whole package with joint kit weighs 1.48 pounds.
Cost: $65.39
Item Number: 006
Part Number: 89040334
Description: BEARING. Center/Intermediate Propeller Shaft
BEARING,PROP SHF CTR SUPT(POWER). Required: 01
BEARING,PROP SHF CTR SUPT(USED WHEN CENTER SUPPORT BEARING DOES NOT HAVE 8MM SHIM. NO COMPARABLE SERVICEABLE 2ND DESIGN WHEN CENTER SUPPORT BEARING HAS 8MM SHIM)(POWER). Required: 01
For: S1(43-53) (2005-2011) (2005 - 2011).
For: S1(43-53) SPORT CHAS PKG(ZQ8),CHAS PKG(Z85),(1ST DES) (2004-2004) (2004 - 2004).
Cost: $87.45
Item Number: 013
Part Number: 89040245
JOINT KIT,PROP SHF RR UNIVERSAL. Required: 01
Joint kit dimensions is 1.70 in × 4.30 in × 4.30 in. Whole package with joint kit weighs 1.44 pounds.
Cost: $65.39
PROP SHAFT (TWO PIECE) (S | Nalley Buick GMC Brunswick
