it also wont hurt to run them off of a relay using the dome light/footwell light wire as the "switching" wire that way there is less stress on the fuse/circuit of the dome light. well thats just what i would do, and if you need help with the wiring of a relay, there should be a diagram in the "aftermarket foglights that look stock" thread or on the12volt.com under the relays section. you could use the relay for "remote wire"
