1 - 10 of 10 Posts
I came over here from the Jeep community. Unfortunately, I'll probably be returning. POR-15 was basically the rockstar of undercoating with Jeeps, and we put our Jeeps through some shit.
Photo of above stated Jeep...
What steps would you take to apply Por 15 to an already-corroded chassis?
I would try try to rid yourself of as much of the corrosion as possible. For surface rust, I used a heavy wire brush, then 80 grit, then dusted it off with a little hand broom, then apply.
If you've got holes & shit, you've got more worries.
No holes, thankfully.
I work and a plant and do undercoating... only think I'm gonna say is absolutely do not use the loctite undercoating it is awful I hate it we have a waterbased undercoat that we use primarily and use the loctite for touch-up and I absolutely hate it!
I just purchased my 05 Colorado with
84000 miles. The undercarriage is very
Clean. Any suggestions on undercoating?
obviously just like paint prep is the key... whenever I paint anything after sanding I use a a product called metal-prep made by dupont. It etches the metal chemically and WORKS REALLY good. It is a water based product and you just wipe it on after you mix it with water 50/50
and rinse off with water and cover.
1 - 10 of 10 Posts
