I'm changing the O2 Sensors in my 2008 Z85 2.9L Colorado with 77K Miles.
Why? I changed the spark plugs and 3 out of 4 of the spark plugs were fouled.
The looked dark, Not oily or wet, just sooty. One of the plugs looked normal (the front one).
So, I replaced all of the Coils and wanted to replace the O2 Sensors as well.
NOTE: I also put some seafoam in the tank to clean the injectors
My question is this. Is there a difference between the Up and down stream 02 Sensors other than the cables?
The reason why I'm asking: I ordered what was described as an Upstream O2 Sensor for my truck but it looks just like the Downstream O2. SO I went back to Rock Auto and sure enough I found another up Stream that looked just like the Up steam O2 in my truck (plug and all).
Can I use the first O2 that I received for the downstream, even though it's considered an up stream at Rock Auto? Is there any diference other than the plug? I have seen other O2 Sensors where you have to build the plug. What gives?
I'm really after the upstream. I just ordered the correct one (I Hope
Thanks in advance:th_woot::355group::th_woot:
Van
Van
