1 - 16 of 16 Posts
So I'm not meaning to make this a "want to buy" although I guess it is implied. I can't find one used so said screw I'll call the dealer. Turns out it's only like 70-75 bucks but they don't stock it. They only way for them to order it is if I have Vin # on a truck the pedal actually belongs to. So don't know if anyone else is stuck with trying to tracked a pre 07 clutch assembly or if you all know of another way. I'm working on an 09 canyon crew cab 3.7 and putting in a 2012 4.8 with a t56.
If this is the wrong place please delete
It has to be pre-07 so it works with the wiring. I'm working with 04colyZQ8, I don't know the science behind just that's what he said.
Sorry 'bout that... this should be what your looking for.
Chevrolet COLORADO EXT CAB CLUTCH PEDAL & CYLINDERS
Item Number: 008
Part Number: 15108400
Description: PEDAL. Engine Clutch
PEDAL,CLU(W/BRKT). Required: 01
For: N1 3.5-6(L52),5 SPD M/TRANS(MA5) (2006-2006) (2006 - 2006).
For: N1 3.7E(LLR),5 SPD M/TRANS(MA5),(EXC RIGHT HAND DRIVE(RHD) (2007-2007) (2007 - 2007).
For: ST1 2.8-8(LK5),5 SPD M/TRANS(MA5) (2004-2006) (2004 - 2006).
For: ST1 2.9-9(LLV),5 SPD M/TRANS(MA5),(EXC RIGHT HAND DRIVE(RHD) (2007-2007) (2007 - 2007).
For: ST1 3.5-6(L52),5 SPD M/TRANS(MA5) (2004-2006) (2004 - 2006).
Cost: $46.66
OK, well I'll do more searching. That's much farther than where I was. Thanks for the help! That was fast.
When I run into a dealer that absolutely refused to help without a VIN, I'll look up the vehicle I want in Autotrader and use that VIN.
Easier, still, use an online service like gmpartsdirect. They won't hassle you for a VIN and it shows up at your door.
I never include a VIN in an order, if I am sure that the part number is what I want. If a seller won't take an order without a VIN, look someplace else.
Discussion Starter #11
So I called back the dealer only this time with the p/n and confirmed it's all the parts. So gmpartsdirect it is. Thanks for all the help.
Yeah my dealer wants the VIN too, but I know the guys in parts now. I just give them that part number and I'm golden. They now know I have a weird build with a combination of 355 Parts :mjb:
Discussion Starter #14
So I guess I'll post in the want to buy section now. Just got this email.
Hello,
Thank you for your order. Part number
15108400 is discontinued and no longer available from GM. This part is now removed from your order. Please let us know if you wish to proceed with the remainder of the order.
Your order is on hold pending your response.
Thank you,
Ashley
GMPartsDirect.com
Internet Troll
On a google search, I see there are 35 dealers with that part supposedly in stock at varying prices.
Good luck and hope you complete your project soon. I'd like to see it!!
I know this was 4 years ago now... but i'm trying to replace my 05 colorado clutch pedal. wondering if anyone has a solution since i cant find the part anywhere.
1 - 16 of 16 Posts
