Okay, so my roommate borrows my truck, clips a carport with the rear axle (HTF did she do it?!?!) and nearly rips the rear end out from under my truck. Sheared the front mount off the rear spring and pulled the drive shaft out from the t-case. Anyway, I end up replacing the spring and replace the seal on the t-case. Apparently I missed the fact that it was still leaking. Leaks all the fluid out, and now the T-Case is....well....RIP.
My question is, after searching for awhile, do the V8 Colorados share the same T150 transfer case as the 3.7, 3.5 etc or is there something different that I don't know about and I have to get a Silverado T-Case. I've looked for a bit and have found an answer enough to satisfy my nerves before I go get another one.
