1 - 3 of 3 Posts
does the water pump pulley come off or is it attached to the pump
on a 5.3 ?
· Super Moderator
It's all one piece Al
Water Pump Removal
  1. Remove the water pump bolts (301).
  2. Remove the water pump (300) and gaskets (306).
  3. Discard the water pump gaskets.
http://parts.nalleygmc.com/showAssembly.aspx?ukey_assembly=372159&ukey_product=2664291
Item Number: 300
Part Number: 19208815
Description: PUMP KIT. Engine Coolant
PUMP KIT,WAT(INCLS GASKETS)(ACDelco #251-713). Required: 01
For: CK1 4.8C(LY2),5.3J W/CYL DEACTVN(LY5),6.0Y W/CYL DEACTVN(L76),5.3-M ALUM W/CYL DEACTIVATION(LH6) (2007-2009) (2009 - 2009).
For: CK1 5.3-0 FLEX FUEL W/CYL DEACTIVATION(LMG),5.3-3 FLEX FUEL W/CYL DEACTVN/AFM(LC9) (2007-2011) (2010 - 2011).
For: CK1 6.0 (LZ1),6.2 W/CYL DEACTVN(L94),4.8 (L20) (2010-2011) (2010 - 2011).
For: CK1 6.0-5 HYBRID USE ONLY(LFA) (2008-2009) (2009 - 2009).
For: CK1 6.2-2(L9H) (2009-2011) (2009 - 2011).
For: CK2,3 6.0 (L96) (2010-2011) (2010 - 2011).
For: CK2,3 6.0-K/N(LY6) (2007-2010) (2009 - 2010).
For: G2,3 6.0 (L96),4.8 (L20) (2010-2011) (2010 - 2011).
For: G2,3 6.0 (LC8) (2011-2011) (2011 - 2011).
For: G2,3 6.0-K/N(LY6) (2008-2009) (2009 - 2009).
For: N1 5.3 (LH9) (2010-2010) (2010 - 2010).
For: N2 6.2-2(L9H),6-SPD A/TRANS(MYC) (2009-2009) (2009 - 2009).
For: N1 5.3-L(LH8) (2008-2009) (2008 - 2009).
For: ST1 5.3-L(LH8) (2009-2009) (2009 - 2009).
For: ST1 5.3 (LH9) (2010-2011) (2010 - 2011).
Cost: $203.36
that sucks, i was going to drill 2 holes in it to hold it while i break
the fan nut lose. looks like i will try the strap wrench i bought.
1 - 3 of 3 Posts
