1 - 14 of 14 Posts
Anyone have any tricks of how to get the white wax marks off my plastic bumper trim and stuff? Or how to prevent this in the future?
What about isopropyl alcohol? And just put on gloves rub the peanut butter in and wash off?
Be sure to use 'smooth' , not 'crunchy' peanut butter. The 'dingleberry' look of the crunchy is not appealing. Just say'n.
:lmaop:
In the past I used WD40!
Be careful using IPA on plastic as it can dry out and crack the plastic. I use Detail Spray to remove wax from plastic. Spray it, let it soak, then remove using a microfiber towel.
Discussion Starter #12
so the conclusion, i fould that wd-40 seems to be the fastest and easiest way to remove the wax from plastic its so east grab a can spray it on wipe it off it makes the plastic clean and relly shiny and probably acts as a rust protector between metal and plastic seams like on our bumpers where rust usually forms first! peanut butter worked too it just you have to wash it off after
I use to do it in Hawaii on the paint to remove water spots too
Sent from my C771 using AutoGuide.Com Free App
While the above suggestions work. The more conventional method is simply a quick detailer spray such as Meguair's or Mother's with a microfiber towel. A soft toothbrush and/or toothpick for crevices.
Respectfully submitted,
BINGO53
1 - 14 of 14 Posts
