2005 z71 163k miles. Stock. So it snowed this morning. Long story short I got loose (in 4wd). Fought it for a while then ended up doing a 360 and went into a steep ditch kind hard (I was going 40 mph when it started). I hit the ditch square. Tried to rock it back and forth and was on my way to getting out when the front driver outter bead went. Tow truck. Spare tire. Etc. I re-inflated my tire and to my surprise it was fine. I think the bead went after I was wrenching it around trying to get out. So I put the re inflated tire on the rear and all seems ok, but I'm not 100% certain what I should look for other than obvious damage. It pulls relatively straight (I need new tires and some tie rods anyway) and no issues I can see. Any ideas?
Also...I thought I had a full size spare. Turns out it's a 235/65/15 instead of the stock 265/75/15. Found that out real fast when I put it in 4wd. Is this right or did they accidentally give me a tire for a 2wd?
Thanks
Thanks
