You guys need to remember that even though the oil is "good" to 15k miles, the oil filter is still only good to 3,500k max. Change your filter on a regular basis even if you have extended life oil.Mobil 1 Extended Performance 5W-30
I run the oil to 5k, then change out the filter w/ new .5qts(fill the filter before install). Then run the oil to 10k and drop oil+filter. AC Delco oil filters...You guys need to remember that even though the oil is "good" to 15k miles, the oil filter is still only good to 3,500k max. Change your filter on a regular basis even if you have extended life oil.
Are you really gonna rely on a $5.00 filter for extended periods of time? Quite a gamble if you ask me.I run the oil to 5k, then change out the filter w/ new .5qts(fill the filter before install). Then run the oil to 10k and drop oil+filter. AC Delco oil filters...
I had the last two oil changes lab tested.. All looked good.
wuss :ghey:I use whatever the dealership puts in!!:lmao: :thumbup:
I can either go to the parts store, spend $15-$20, and get dirty doing it myself, or I can spend $25 to have them do it while I sit in the lounge and read the paper!......no brainer in my book.
Actually, $2.86 a filter... 5k is something fleet vehicles do with less than AC Delco quality filters and dino oil. :shrug:Are you really gonna rely on a $5.00 filter for extended periods of time? Quite a gamble if you ask me.
you could do a synthetic oil change in your garage for $25...ask the dealer how much they charge for thatI use whatever the dealership puts in!!:lmao: :thumbup:
My last one was over $80...:dawg:you could do a synthetic oil change in your garage for $25...ask the dealer how much they charge for that![]()
same and their filter.Regular 'ol Mobil 1 Snyth 5w30 here.
