1 - 8 of 8 Posts
4 cylinder 4 speed auto 373 gears. At 60 in hi gear with torque converter locked I am at 2000 RPM. Is this normal?
CALI BOSS
That sounds a bit slow. With my 3.5L auto 3.73 it would run at 80 mph at 2500 rpm. Same with my current 3.5L 5M 3.42 it runs at 80 mph at 2500 rpm
Crewcab 2.9L with 3:73 limited slip, i think mines at 1,800 and 2k at 65mph ... will double check on my next drive ...
2012 GMC Canyon
I have 3.73’s and I turn about 1800 rpm at 60. Are you sure your speedo is correct ? Do you have stock tires ?
sorry for the late reply, yep 1,800/60 and 2,000/65 ... can you verify/compare speed thru the OBD2 port vs gauge ?
CALI BOSS
That's a good point ^^^
Use your phone and a navigation app and verify your speed via GPS as well
Sent from my SM-N960U using Tapatalk
I will use GPS for speed and report back. Thanks guys
1 - 8 of 8 Posts
