Hey all. I suspect a 'weak' spark is happening on my 3.5L, causing a somewhat rough idle and a noticeable groan / vibration between 1300 and 1500rpm. It doesn't matter if I'm moving, or if stationary (in gear, feet on gas and brake), the noise / feeling is there. I've checked compression and we are 170-175psi across the board. Next thought was the hissing sound coming from the tube via the valve cover to intake manifold. Research here stated the hose would need to be replaced to stop that. That of course equals a full new intake manifold as there's no good way to remove the cover w/o either destroying or cutting a hole in it (didn't want to do either). In any event, while that was not fun to replace and did get rid of the hissing, the sound / vibration remained.
So that brings me to the coils. In testing them, cylinders 1, 2, 3, and 5 show 12k ohms. Cyl 4 shows 11.94k ohms. I am unable to find what a good resistance is and from those I can, the range highly varies. On top of this, the plugs were recently replaced. Only the #4 plug shows a little tarnish on the white insulator. The other 4 remain white.
So, would a slightly weak coil (assuming 12k ohms is standard) cause the 'rough' idle and noise / vibration at rpm? There is no OBDII codes or Check Engine light on.
Note: have pics if one would like to see various things.
Edit: There is no significant loss in power. Only notice a 'slight' loss (on hills I traverse daily) and a decrease in fuel milage.
