ok...
How about a 15x8.... 5.25 Backspace.... *20.32 offset....and a really big smile?!?!?!
hey duckie i went ahead and ran those numbers and if you go with these it should be good on inside clearance BUT will stick 8mm (.3") outside of fender...so it might not be bad might have to do some trimming on the fender maybe...
if you are looking to sit flush you need atleast a 27mm offset and that would bring it in 1/2 inch closer...so find a 25mm and you should sit near perfect...
also if you lower it you will have to run smaller sidewall to make sure it dont rub...my stocks rub on decent dips and im 3/4 dropped...a 65 or 70 series tire would be best...prob 65 being the better...
ok one more thing these numbers are all according to the calculator im not saying to go right ahead and get them...if i did and u got them and they dont fit then i look like an ass...lol so im just saying sccording to the calculator it looks like it would fit but i suggest test fit before buying...
