1 - 13 of 13 Posts
I'm wanting to change things up on my truck. At the moment I'm leveled with a 2" crank and stock rear and have 20x8.5 rockstars with stock equivalent backspace. The tires are 275/55r20 terra grapplers which are basically 32 by 11. I'm looking at getting 17x8.5 fuel octanes with -05 offset with 265/70 trail grapplers. The tires have the same specs as my current ones. I was figuring that the less backspace would help me clear my balljoint. Does this sound right?Long story short does anyone believe that this new setup would not fit for any reason? Thanks in advance
If you mean the wheel has a -5mm offset, then you should be fine. That's a 4.6" backspace.
The tire is a standard size tire and the wheel is pretty common too.
FYI: I have the 16" equivalent tire size and clear with a backspace of like 5.2" or 5.3" (I forget what it is).
I understand. BUT, the OP should be aware of what he's typing.
In the real world, if he goes around typing out 05 and he means 5mm, it's not the same thing.
In the context of what he was typing it's no big deal. However, from an informative point of view it's important to write out his question accurately.
Making a typing error happens all the time, but he wrote it incorrectly twice. The same 'typing error' twice sounds like a misunderstanding of the proper way to write it (to me).
And now he isn't here....LOL
I can't function in my job with that...if somebody came to me and asked me to draw a line segment 05 from the other line, I'd have to get confirmation before proceeding.
Discussion Starter · #12 · (Edited)
Forgive me for the error yes I did mean -5 MM of offset for the wheel. I was actually just typing what I read on the website that I saw the wheels on. I just wanted to confirm that this set up would clear everything. Sorry for the confusion
Here's the url to the website that says -05 for the offset. In my mind I knew what it meant and I figured both -05mm and -5mm meant the same thing. Sorry again
http://rimzoneonline.com/wheels/fue...x8-5-fuel-octane-matte-black-d5097859845.html
1 - 13 of 13 Posts
