1 - 11 of 11 Posts
Will the wheels from an 2015-2018 Canyon (255/65/r17) fit on my 07 Canyon sle crew cab
2010 Colorado 2lt Crew Cab Z71 Off Road 4x4
I thought the new gen were a different bolt pattern than the gen 1 Colorado / Canyons. The old one was a 6x5.5" which is a 6x139.7mm in the metric size.
2006 GMC Canyon
The bolt pattern is different. You will need to go with spacer adapters. I’ve got the same setup with my 06 crew cab had them on for close to 2 years and have not had a problem yet
there are spacers as well as adapters, both push your wheel out but adapters change bolt pattern + are generally thicker for safety needing more metal to hold the different studs. depending on your wheel offset issues can occur!!
1 - 11 of 11 Posts
