i thought one was easier than others. jtr maybe?they look to have the same connection points, so probably about even on ease of installation...
get one, best tool EVAR!I need a SAWZALL!!!
the beltech one is 214.56 from compI was looking at the jtr x-member pics again and it looks like it could be done with a sawza and a new blade. I would say that this is going to be the easyest one to install. I think the belltech one isnt even out yet and it looks like it installs pretty much the same as the jtr. But I beleave the belltech one is going to costs alot more than the jtr x-memeber.
I may be wrong...but by the looks of the bracket...wouldn;t you still have to remove the whole thing. I just don;t see how on;t chopping off the bottom section would allow for the new crossmember to be installed to the frame rails. Does anyone have pics of the xmember installed??????????You only have to trim the brakets if you dont want to remove them for the jtr.
Yes you have to drill holes in the side of the frame for both the gtc and ccc. The hardest thing to do is remove the brackets thats it. Everything eles is super easy. Come on guys you can do it.
the JTR bolts from underneath...not inside the frame rails like the two that were posted.I may be wrong...but by the looks of the bracket...wouldn;t you still have to remove the whole thing. I just don;t see how on;t chopping off the bottom section would allow for the new crossmember to be installed to the frame rails. Does anyone have pics of the xmember installed??????????
