I have a crew cab this is a regular cab in the listing I emailed him asking about tire sizeThe truck in the picture looks like it's probably the same truck as yours (2wd Z85).
If it isn't what you drive, ask the seller what size the tires are too so we can determine how big/small they will be for your truck.
I am sitting in the sun and I can't see detail on my screen too well, so if that truck isn't what you have then I apologize in advance.
It's not. An 8" rim is the perfect size for a 235 tire.But I think an 8" wheel is too wide for a 235 (9") tire.
Depends on the profile height.It's not. An 8" rim is the perfect size for a 235 tire.
The cab won't matter. As long as one of them aren't a 4x4 or a W/T vs Z85.I have a crew cab this is a regular cab in the listing I emailed him asking about tire size
I ran a 275/45/20 on a 20x9.5 wheel
If you're trying to say it didn't rub, you need to specify the offset or backspace value.I ran a 275/45/20 on a 20x9.5 wheel
Does the seller say they rub his truck?
I was just worried about the width of his tire and rim a nd the difference in cabsI don't see a need for spacers then, if he clears.
You guys have the same truck.
