I sincerely appreciate your response, but I'm lost. History, the cruise control and wipers/washers stopped working. I figured the multifunction switch was bad, so I grabbed one from a U-Pull lot. The cruise control started working, but still no wipers. I connected test leads to the battery and all worked correctly. I started assuming that the BCM was bad, but in he back of my mind, I considered the possibility that the used part I got may have been somewhat better than mine, but it could still be the reason for the problem. After pulling the steering wheel and wrestling with those nightmare clips to get the air bag out, I was not really anxious to perform that task again. After constantly coating my windshield with Rain-X and having to pull to the side of the road in some really bad downpours, I broke down and ordered the $150 multifunction switch and replaced. Then wipers worked, but always on high speed.
The relays you are referring to, are the numbers you give the location in the fuse box? Basically, if I replace both 57 and 63, I should eliminate all possible bad parts except the BCM, correct? Since the truck runs great and everything else works as it's supposed to, I feel pretty confident that it's not the BCM.
Thanks so much for your response! Have you ever replaced one of those switches on a Colorado/Canyon? It's a nightmare! I've replaced several of those switches on other vehicles and most mounted to the side of the column. Only one other one required removing the steering wheel, but it did not have the stupid little access hole to somehow magically activate those 4 clips when you have absolutely no idea where they are, how to depress them one you find them and there are no clear descriptions of what you are attempting to do completely blind to what's inside that little access hole. I could get one or two, but working on the third one always re-locked the first two that I had released. I remembered that there were two small torx screws on the backside of the steering wheel that seemed to hold those spring clips in place, so I removed those and shoved a screwdriver in the access hole and broke them loose. I always grab a few spare parts when at the U-Pull lot, so I knew I had replacements to put it all back together, including a spare steering wheel if needed.
Thanks again. I'm happy to have wipers again, but I'll be happier when they are completely correct.
