I beat my brains out working on mine. The grease in the motor gets all gunked up and it messes up the contacts inside. Have you tried manually moving the wiper arms? Also, the ground is in splice pack 105. Cart can tell you better than me which one that is. When I hear contacts clicking, but nothing is happening, I've found it to be either low voltage or a bad ground. Specifically if it's a "click, click, click" sound. There are two relays, a fuse and also a diode all associated with the wipers. Ultimately, the cruise control stopped working as well as the wipers and I replaced the multi function switch. I sure hope you don't have to replace that. Getting that airbag off of the steering wheel is nothing short of a magic trick! There are videos out there, but they can't really show you what's going on. You have to just fiddle around blindly and once you get one or two of the clips unlocked, you start on #3 and the first 2 lock back in place. It's a terrible nightmare! Do some voltage tests and let us know what you find.
